configure igmp snooping timer
configure igmp snooping timer router_timeout host_timeout {vr vrname} {vlan vlan_name}
Description
Configures the IGMP snooping timers.
Syntax Description
router_timeout Specifies the time in seconds before removing a router snooping entry.
host_timeout Specifies the time in seconds before removing a host‘s group snooping entry.
vrname Specifies a virtual router.
vlan_name Specifies the VLAN name. If no VLAN is specified, the setting is applied to all existing VLANs.
Default
The router timeout default setting is 260 seconds. The host timeout setting is 260 seconds.
Usage Guidelines
Timers should be set to approximately 2.5 times the router query interval in use on the network. Specify the following:
  • router timeout—The maximum time, in seconds, that a router snooping entry can remain in the IGMP snooping table without receiving a router report. If a report is not received, the entry is deleted. The range is 10 to 214,748,364 seconds (6.8 years). The default setting is 260 seconds.
  • host timeout—The maximum time, in seconds, that a group snooping entry can remain in the IGMP snooping table without receiving a group report. If a report is not received, the entry is deleted. The range is 10 to 214,748,364 seconds. The default setting is 260 seconds.
    The host_timeout value should be less than or equal to the query timeout value, which is defined by the following: (query_interval x robustness) + query_response_interval.
IGMP snooping expects at least one device on every VLAN to periodically generate IGMP query messages. Without an IGMP querier, the switch eventually stops forwarding IP multicast packets to any port, because the IGMP snooping entries time out, based on the value specified in host_timeout or router_timeout.
The following example configures the IGMP snooping timers:
configure igmp snooping timer 600 600
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IGMP snooping feature, see the Switch Engine v33.1.1 Licensing Guide document.
